Use this procedure to view the LLDP neighbor information.
  1. In the navigation pane, expand Configuration > Serviceability > Diagnostics > 802_1ab.
  2. Select LLDP.
  3. Select the Neighbor tab.
Neighbor Field Descriptions
Use the data in the following table to use the Neighbor tab.
Name
Description
TimeMark
Indicates the time filter. For more information about TimeFilter, see the TimeFilter textual convention in IETF RFC 2021.
LocalPortNum
Identifies the port on which the remote system information is received.
Index
Indicates a particular connection instance that is unique to the remote system.
ProtocolType
Indicates whether the entry protocol is CDP or LLDP.
SysName
Indicates the name of the remote system.
IpAddress
Indicates the neighbor‘s IP address.
PortIdSubType
Indicates the type of encoding used to identify the remote port.
PortId
Indicates the remote port ID.
PortDesc
Indicates the remote port description.
ChassisIdSubtype
Indicates the type of encoding used to identify the remote system chassis.
  • chassisComponent
  • interfaceAlias
  • portComponent
  • macAddress
  • networkAddress
  • interfaceName
  • local
ChassisId
Indicates the chassis ID of the remote system.
SysCapSupported
Identifies the system capabilities supported on the remote system.
SysCapEnabled
Identifies the system capabilities enabled on the remote system.
SysDesc
Indicates the description of the remote system.
